Bleeding New Power Steering Pump? 1993
Is there some kind of trick to doing this on an FZJ80 with (RAWL) "Four Wheel Disk Anti-Lock Brakes)? My kinda buddy:rolleyes: at the Toyota dealership said 'I can't do this properly without having an electronic brake testing computer':confused:. Is this really the case? It dose not make any logical conection with me, and he won't expand on why this would significant. Thoughts....Cheers, Skyler
Do you mean that you want to remove any air from the power steering fluid after having the pump replaced? There's a FAQ about flushing the power steering fluid. It covers residual air removal.
Never heard this about the compiuter.
Using the two buddy rule and following the FAQ and FSM you should be able to bleed this just fine. You will be able to tell by how the brakes feel when they are done.
I think I got this figured out.
Thanks guys, I looked a little deeper in search and found a likely source of this strange rumor. I guess Chilton's repair manual for Toyota: pick-ups, Land Cruiser and 4runner from 1989-1996 said somthing about not beeing able to flush power steering fluid if you have ABS. What a friggin joke:grinpimp: I'm just going to do it like I have done on every other car or truck I've owned. Thanks again, Cheers Skyler.
Damb dealer service writers and all in one aftermarket repair manuals!;)
Actually, I think he is talking about bleeding the power steering pump. But how the PS relates to the brake system doesn't make any sense to me, so I'm lost.
You can definately bleed the brakes - though it can be a pain if you don't have two people or a fancy pump system.
You can also flush the power steering system - I'm not aware of a 'bleeding' issue, but I just followed the FAQ (thanks Romer!).
Good luck - repost if you need to clarify the issue.
