Bleeding cooling system?
San Diego
Well, I just (almost) completed one of the worst days of PM'ing my rig ever:rolleyes: I think that just about everthing that could have gone my way, didn't. In the end I ended up repacing all of my hoses (yes, including the PHH and FHH with silicone), replacing my thermostat and flushing the cooling system in addition to removing the factory P/S cooler:mad: and plumbing my Hayden tranny cooler to my P/S.
The worst part is that I think the hose I used for the P/S is one size too small. I had and used 5/16 but I am going to re-do it tomorrow with 3/8. The 5/16 just wasnt big enough to get onto the fittings but my rig was torn apart and I had to use the 5/16 temporarily to get home.
So here's my question: Is there something more I should do than just refill the cooling system? I swear that I read a thread once that referenced bleeder bolts or something. The FSM merely states to refill the system and "bleed it" with no more details. Everything seems fine right now and I even think it's running a little cooler; a little more time will tell.
Thoughts, opinions?
No, right now my temps are centered around 180, totally fine:)
some motors have a hard time expelling air naturally, they have bleed screws, fortunately the 1FZ is not one of them it has a bleed line that carries air to the radiator and then exchanges it for fluid in the overflow.
Do check it often for a few days though.
As long as you put the thermostat in correctly with the jiggler valve at 12:00 AND you have a working radiator cap, it will purge itself of air over 3-4 start cycles. Keep the overflow bottle full, and it will push out air, and suck in coolant. Open the heater valve for 30 seconds at start up each time for 3-4 start cycles.
Er wait a minute, I was just reading somewhere (maybe the FSM) that there is a coolant bleed on the block somewhere. Yes, here it is:
Strangely enough, I paid attention the jiggler valve when I disassembled it and it was at 9:00. That's where I put the new one too. Disheartening since my rig had only been worked on by Lexus mechanics prior to my owning it:rolleyes:
That's actually a drain. Theres no way air could be expelled from it if the engine is full of coolant.
Considering I have a Cruiser from every era, I've never seen one that had a bleeder valve or had to be bled. You can bleed a 2F by pulling out the temp sender, but it is not needed. You must have a working radiator cap or it sucks air back into the cooling system. That's why it's worth replacing every time you work on it, or every 4 years or so.
