Blast media?
Kansastitty
I want to get a table top blast cabinet to do some carburetor parts. Should I use plastic beads, walnut shells or something else? The carb I want to clean up is very, very nasty, beyond Berryman's and my parts washer. Obviously I don't want anything too abrasive and I'm leaning towards the walnut shells, but have never used them. Will they take off rust and corrosion?
Thanks,
Ed
You're not goint to hurt it with aluminum oxide, except for maybe plugging passages, which you have the risk of doing under any circumstances.
Personally, I'd get some real nastyass carb dip, like from NAPA, and a brush, and just keep doing it over and over until it cleans up. It will.
Ed-
Is the problem gunk on the inside/outside?
If so, go get a couple gallons of laquer thinner, and soak it in a bucket for a while...it will come clean..
Corrosion/rust?
Glass beads seem to work fine for me, from carb parts to shift linkages, housings, etc.
The only problem is that any blasting media can and will get caught in passeges, so be sure to clean very/blow out very well. If not, you will be pulling out your remaining hair..
Good luck!
-Steve
I called a buddy who works at a machine shop that rebuilds, among other things, ordinance manufacturing machines for the Lake City Ammunition Plant. He is bringing me a couple of gallons of the solution they use to hot tank stuff. It is aluminum-safe and presumably zinc-safe. The throttle body is pretty rusty and both the aluminum and the zinc(air horn) are pretty corroded.
Ed
Here is what I'm up against. Even if I can just clean and save a few parts. I'm not needing the whole thing, necessarily.
Ed
That's not too bad. mine was like that I dipped it in laquer thinner for 24hrs brushed it off and repeated, it is not perfect but it is much much better
I've tried the walnut shells. I can't reccomend them. They are gentle on the metal sufaces but also gentle on the gunk you are trying to get rid of. Very slow and required wire brusshing to clean it all the way.
Laquer thinner and a variety of wire brushes works the best.
