I drove straight across knowing it would high center. If you have a shorter wheel base or bigger tires you may be able to walk straight over. The line I took in the video should not eat a transfer case. Slider maybe depending on clearance. With traction aids and a different line you should be ok. There are other vids on YouTube that show some lines across the middle. I just didn't want to get crossed up travelling solo.So by looking at the photo. If I didn't have a skid covering the transfer case I would most likely mess it up right? I may need to winch 2 times. Might as well leave the cable out the whole trip since it is a pita to pull out.
