- Location
- United States
HI Guys, I just cleared out a small mine inventory, there are lots of parts and pieces for BJ/PZJ/HZJ and some HZJ79 cruisers. I haven't posted prices as I dont have time to set prices on everything on the list - and probably more coming. The deal will be a good one though. Email for more info - and I do have more parts so please inquire.
Part Number Description Quantity Models
37140-60170 Drive shaftlong end - new 50.00 1 BJ7X 50.
Brake lever, parking brake shoe 1 All $50.00
48412-60010 Braket, Front LH leaf spring mount 1 BJ7X, HZJ, PZJ
90366-17007 Tapered bearing, steering knuckle 1 HZJ, PZJ
04493-60030 piston kit 2 ?
42431-60020 Brake drum – rear 2 BJ7X 50 each resurfaced - new condition.
44610-60460 Brake Booster 2 LJX, BJ7X
90363-12002 Bearing Input bearing – clutch 1 All
90506-26014 Spring brake Shoe return 1 All
90312-3200? Seal 1
96940-39855 Brake hose 1 all
17401- Exhaust front pipe-from manifold 1 BJ
45044-69145 Relay Rod end 4 All
45046-60H05 Relay Rod end 1 HZJ7X
45047-69085 Tie rod end 4 HZJ/PZJ
42312-60140 Axle Rear left 1 HZJ/PZJ
48511-60540 Shock 1 ?
43232-35010 Knuckle bearing cap 1 All
20501-12033 Spring 1 ?
Manifold studs 4 All
43423-35010 Cap front axle flange 8 All
41331-35020 Side gear- rear diff 2 BJ7
47612-60010 Brake emerg adjust lever LH 5 All
04445-60030 Gasket kit- power steering 1 BJ7X
33348-36012 Washer – 1st gear thrust 1 All
47626-60010 Brake adjuster 1 All
90179-22005 Pinion nut 1 All
43422-60020 Gasket, rear axle shaft 1 BJ
43411-60020 Axle, inner RH 1 BJ7X
90520-27091 Snap ring- front outer axle 1 All
E-brake adjuster cable 1 All
47201-60600 Brake master cylinder 1 HZJ/PZJ
New and used parts – useable with no numbers – but can find application
Birfield
Misc brake parts, shoes, clips, springs, adjusters etc
Used brake booster
windshield hinges
New rear diff cover HZJ/PZJ
Hubs
Shims
TRE
Hub parts
PTO winch shaft assembly for BJ models – possibly HZJ73 as well
Window crank inner door mechanism
Door handles for pick up
Door latching mechanism
Interior door latch
Rad overflow bottle
90312-3200? Seal 1
Birfield
Used brake booster
windshield hinges
Hubs
Shims
TRE
Hub parts
Interior door latch
Rad overflow bottle
