BJ74 Manual to Auto Conversion.
Townsville, Australia
Yes, you read right. I want to go auto.
I believe these things came out with an A440 Transmission as did the 60 series. So locating a transmission and Converter should not be a problem. I assume I need the Auto Flywheel as well.
Which 60 series Transmission/Engine has the same bolt pattern as the 13BT?
Ummm Flywheel??
Trans Cross member? is it the same as the Manual gearbox?
Transfer Case. Do I need a particular output shaft on the auto?
What about the total length of this assembly? Are drive shafts effected?
OMG. is it really worth it? Probs not. but I'm going to do it anyway.
Any and all help is really appreciated.
If it makes a difference. I'm in Australia.
