I have an '87 BJ73 with 13B TD engine and 24VDC electrical system. My A/C compressor has locked up. Can anyone suggest a source for a replacement. The faulty compressor is a Denso 047200-8720. Other numbers on the tag are 0G-0026 and JOP15C.
Hello Chevota3232,
We do have those compressors, they come with a 12V clutch coil, you may have to install you clutch assembly on the Denso compressor.
give us a call for more info toll free 888-438-9534 local 520-918-3604.
Jorge.
Any thoughts on a replacement clutch for a BJ74?
(who might have one)
What all is involved in swapping the clutch coil? Any pics of the process?
Available from Toyota USA for $531:
http://www.toyotapartsdeal.com/oem/toyota~clutch~assy~magnet~88410-60070.html
I paid $350 + $50 shipping from Amayama. Obviously took a bit longer but if you want to save money...
Have a couple more brews and they'll be good!I'm on vacation. My maths don't work.
OR have a few more brews and you won't give a damn.Have a couple more brews and they'll be good!
The compressor I got from Coolstreamac came with a new 12V clutch.
The awesome a/c tech I found in town swapped just the 24V magnet; the new clutch pulley, bearings, etc. remained on the new compressor.
I think if I was looking to replace the clutch I'd go 12V with a 24V/12V relay.
Most AC shops can find you a comparable replacement, and then you'll have to use your 24v clutch or wire a converter and relay to operate a 12v clutch. Try part number 57389.
Actually not too difficult, especially if I can do it, which I just did a couple weeks ago. I had a 12v clutch with a relay center tapped from my 24v system from the PO. Ordered the appropriate 24v clutch from Amayama and switched them out to get my wiring in order. Only tools needed were snap ring pliers, appropriate sockets and a strap wrench to hold the pulley while loosening the nut. Loosen belt, remove nut/washer, pull clutch drive plate and spacers, remove snap ring, remove pulley, remove second snap ring, remove magnetic coil, replace coil then put back everything in reverse order. All of the above courtesy of ih8mud forum search.
I'm in Denver if you want a hand.
