All i used: 10,12, and 14 mm ratcheting spanners, with swivel heads, a 1/2 and a 1/4 socket wrench with the same socket sizes, and a Philips for the mud guards and some bolts inside the cabin. A small 1/4 that can use 14 mm or a ratchet spanner is gold, space is very limited.
The fender is connected to the car on 2 sides, the upper side, the one that you get to through the engine compartment and the door - it is, more or less a straight line of equally distant bolts, and the lower side, that starts at the very front of the car, then goes all along the wheel arch, down to the sill - obviously forming an arch; no bolts on the vertical side. I believe there are 12 bolts on each fender; the 2 bottom ones - photo 3 - are longer, the one in the front is shorter - photo 2 - and, i think, the one near the 2 longer ones, is also short, but they have the same head, 14 mm. The rest are identical, as far as i can see. The bolts go through the metal into clips - photo 5, make sure not to loose those when the fenders come off.
The 12 bolts are all 14 mm, the various bolts inside the engine compartment are 10 and 12 mm, the hinges bolts may be 14 or 12, can't remember.
This is what i did for the right - passenger:
I took out the radiator grill and the body-part underneath it, in order to get to a tricky bolt in the front - left-down corner on photo 2. Took out the bolts inside the wheel arch, just the ones to the outside of the arch, took out the side steps to get to 2 hidden bolts (photo 3 on the left, looking straight up). These are the 2 longer bolts.
In the engine compartment, i moved the window washer reservoir and the air box (3 bolts, one underneath); i also took out the plastic sleeve that runs across the radiator/fan, in oder to be able to move the filter box. Next, i took out the battery. All of this just to have access to the bolts.
The final 2 bolts are very far from the engine opening, close to the door, so i had to move the door. I only want to paint the fenders, so the doors didn't have to be removed completely; i pulled on the electrical connections as far as i could without braking something, so the door may be moved by some 15 mm, i moved back the rubber boot and got out the pin holding the door stopper - the metal bit that holds the door from opening too far, then i unbolted the 4 bolts holding the 2 hinges to the door (make sure to clear the electrical connections and brace the door somehow, then keep the last bolt to be taken out on the upper hinge, so you are upright when it's done, you may need to hold the door), and i moved the door slightly to the back of the car, in order to have access to the final 2 bolts - photo 4, difficult to see.
The left hand side is easier, no washer reservoir and air box to deal with, the rest is the same.
