BJ45 transfer / transmission
Ibiza
Hi all. Wondering if anyone can help, got the boxes out on a BJ45 but cant separate them. Have looked at all the threads in here amd countless YT vids and cant see the answer, it seems there should be 5 bolts holding them together but I can only see 4, as per pic?
that transfer case needs to be dis assembled to remove it from the transmission
it is known as a split case
remove the pto cover
you need to remove all the bolts around the middle of the transfer case
when you remove the rear half of the transfer case
there will be 2 or 3 more bolts on the inside that hold the front half of the case to the transmission
remove the pto cove
Thanks amigo.
