BJ40 Tacho
Hi,
i have a 1978 BJ40. It has no tacho, however someone on ebay is selling a tacho from a BJ40. Does anyone know how i would wire this up? as im quite interested in it.
Thanks
Ryan
RyRy said:
Hi,
Thanks
Ryan
Got a link to it?
Well RyRy,
i've got wiring diagrams for BJ40 US and Canada as well as one for all except US and Canada, and none show a tachometer at all, optional or not. So my diagrams are for earlier models than those that might have had that gauge.
The metal surround of that meter looks like the kind found in BJ42 & 44 and others probably which are as far as I've known the models which supercede the BJ40 after 1978. Maybe the seller has the model wrong? Or very possibly the BJ40 went on in production longer than I know.
Either way I can't help - sorry.
It's a diesel tach. Since there's no coil or distributor, most of them use either a sensor on the flywheel or a mechanical connection. Would be pretty tricky to get it to work with a gas/petrol engine.
That tach is for a BJ42 . Canada got them in with a tach in '83 and '84
They have a sensor in the bellhousing that counts teeth on the flywheel. Your BJ40 will have a flat spot where the sensor goes but you'll need to drill and tap it. Its not likely possible while in the truck so its the kind of thing you'd want to do when doing a clutch. Probably easier to source a bellhousing from a '81-84 BJ60. It'll have the hole and likely the sender too.
