So, I just got done doing a complete knuckle rebuild including switching the birfs from one side to the other. The clicking is gone, stoked!!
When I pulled the birf out I could see that the grease had been slung out of the joint to the inside of the ball swivel housing. Physics tells me this is normal. So I started thinking of a better way to keep the birf always lubricated.
I work on a lot of Land Rovers and they have a lubricant for their birfields called Quick Shot. It is a tube that is pre measured and fills the ball swivel with a grease that is more liquidy than most. I used this grease on my FZJ80 thinking that the birf is submerged in a grease that has the ability to get flung around the ball swivel and not stick to the sides. Instead it settles in the bottom and gets sloshed around as the birf spins.
The question is if anyone knows what amount of grease should be inside the ball swivel. The ball swivels on the Rovers is smaller than the FZJ80 and I can't find a spec for suggested amount of grease. Anyone out there got any pros or cons to using the Rover grease. I think it is a good topic to toss around. It gives the ability to remove the grease with a suction tube from the ball swivel access plug and thus makes servicing them much easier. Any thoughts?
