Birfield Making Metal - why?
Peachland, BC
So I had an axle seal go on the long side, and when cleaning and inspecting found that the outer edge of the birf has been grinding. I looks like its shaved off a more than 1/16th. Pic below shows the short side for comparison.
Has anyone experienced this and know why this may be happening?
Some History if it matters:
Axle rebuilt about 30,000 ago with genuine including new bearings. Had death wobble last year which I traced to dead shocks and a tire re-balance. Lately with new tires I get the odd wobble periodically - re-balanced again and wobble gone - running 35's, 4 inch lift. Castor is within spec, all panhard, tie rod, sway bar and knuckle bolts are tight. All suspension bushings are no older than the axle rebuild. I am part time.
The place on the inner axle where the axle seal sits is in good shape. No noticeable groves or gouges
Possibilities:
1. C clip not installed on end of Birfield shaft
2. Wrong drive plate installed.
3. Damage inside knuckle bell creating interference.
Thanks Pin Head, plates are correct and knuckle is fine - not sure about circlip - assuming clip at end of inner is what you mean? I'll pull them apart to check. Clip was installed at hub end of birf.
Is it possible that abs sensor or senor mounting bolts can cause interference or the grease fill plug on knuckle housing? I think I'll pull these to look.
Its back together now with new birfs and I don't want to pull apart. but...
The brass bushing in the spindle could be worn allowing the birf to move around inside the housing.
I have the old ones - but can't compare them from new but can slip them over the birfs to see how much slop there is
My passenger side looked just like this, I could occasionally hear something grinding over there. Another indication that something was wrong was the camber was out on that side. I installed new spindles, trunnion and wheel bearings on both sides and that fixed it. I guess the trunnion bearings could have also played a role.
