birfield issue?
Just rebuilt my knuckles last night .set the preload without the birf in the axle .After installing the birf (longfield) the tension needed to turn the axle increased significantly.The longfield innercage seems really tight to me and I have noticed a repetative but slight knock from the side which had this birf in it .I was hoping It might just be tight from bobby's process and not yet broken in .the truck has probably had only about 500 miles in 4 wheel drive since the longs were initially installed. I guess my question is should I finish the rebuild and drive it or stop now and get a new birf from bobby.I stopped after the spindles were bolted on .
The longs are tight when they are new. Put it together and run it, they are completely normal.
