Birfield help
Seriously, when you get the axle out of the birf it's five minutes to be cleaned and ready for grease. Why the hell wait over night for cleaner to soak in? I also cannot for the life of me see how it could ever get complicated unless you've been enjoying step 6 too much.
Bear80,
I didn't say the birf disassembly was complicated, I said reassembly was problematic and that term conveys what I intended. ;) Your neighbours must have been proud having all those redneck Texans drinking beer, blaring the stereo, and taking apart their trucks in the driveway. :D
aurunner18,
You don't need to soak the birfs overnight unless you just want to. Remove the axle, use a parts cleaner or a 5-gal bucket to clean the birf, wipe it out and carefully pack with fresh moly grease.
-B-
Bear80,
I didn't say the birf disassembly was complicated, I said reassembly was problematic and that term conveys what I intended. ;) Your neighbours must have been proud having all those redneck Texans drinking beer, blaring the stereo, and taking apart their trucks in the driveway. :D-B-
I see where you're comming from. I know may times it's hard to convay meaing on the forum and then eveyone interperates it different too. A lot of us forget what it's like working something for the first time or so and the possible areas of complications.
I always just thought my neighbors where quite people.....:D
My bad, by that time we had about 6-10 step 6's:beer:. We also tried the ziptie method but it was more problematic than just removing the clip and adjusting it.
I guess I'm really trusting of others.....though Josh did lose the drift and it bonked my head once. :doh:
can someone clarify the whole c-clip thing for me?
I"m planning to swap the birfs tomorrow, should I buy c-clips to replace the old ones? Or should i plan to re-use?
part number for the c-clip anyone?
The inner c-clip tends to get sheared when you take the birfs apart, although in the 80 it's less likely than a 60. They are very cheap. so the smart money says to have some on hand.
gotcha. added them to the list of things to get at the dealer tomorrow (hopefully they are in stock)
