I am doing my front end rebuild this weekend, and the only info i am lacking is about the rotation of the birfield from diver to passenger. Can anyone send em to the correct link or correct diagram for the disassembly and reassemble of the birfield. I have a 93 80.
I would disassemble whether you switch sides or not. I tried really hard to get mine clean without taking the apart (used gasoline, brake cleaner, soaked overnight, etc). I then decided to switch sides and when they came apart there was still alot of old grease (and solvent) down in the bell even though they looked clean when they were assembled.
Do you have the fsm? The (dis)assemble precedure is in there. I used the pvc trick to take them apart and a vice or second person makes it alot easier to put them back together. Also pay attention to orientation of the star piece when you take the apart.
If you leave your birfs in a bucket filled with any of the cleaners mentioned above over night, it should brake apart all the grease in the birf assembly...(Notice I said "IT SHOULD." )
After two birf jobs on my truck and on four other trucks, breaking the joints apart is not only easier but much quicker. Just remember that you'll probably want to pull the c-clip off and crimp it back down before you try to reinsert the axle shaft.
Some paint thinner and a paint brush in a shallow pan works just fine for a parts cleaner. Just hand wipe as much grease off as possible before using solvents. Then some brake cleaner as a final step in cleaning.
I wouldn't bother. Clean them out well with a parts washer or bucket of solvent (mineral spirits is my favorite), then dry them out, grease with your favorite Moly lube and re-install.
Ask Beowulf about Birfield assembly, he is the master.
So what diagram are you looking for? When you swap driver to passanger side, all you do is put a different axle in the birfield. OR are you looking for the orientation of the cage and inner star when reassembling the birf?
No idea how you're using a screwdriver to compress a c-clip. The zip-tie couldn't be easier - cinch it tight, put axle in, zip-tie slides off and c-clip uncompresses inside bell - cake.
I'll have to show you... If I tried to type it I would confuse myself. As for the Zip-ties, if I tightened them enough to compress the clip, I couldn't get it to slide. Maybe I just need to buy cheap zip-ties!
If you disassemble them, try to schedule the reassembly in the morning after you've had a good night's sleep. Putting them together at midnight is problematic.
I don't think I would take them apart again. The difference in 'cleaning' isn't worth it.
Thanks for all the response, I am going to disassemble the front this after noon and let the birfields soak in diesel over night then swap the axle shafts, if beowulf says it is not worth taking them apart then i wont bother.
Seriously, when you get the axle out of the birf it's five minutes to be cleaned and ready for grease. Why the hell wait over night for cleaner to soak in? I also cannot for the life of me see how it could ever get complicated unless you've been enjoying step 6 too much.
BTW. Just a few weeks before we did the double birf job I helped another member do his. You might remember he lost a stud on the knuckle while out on the trail last month. He tired the soak in diesel since he started the night before I came by. Even after soaking it took way longer to clean out. Guess what?? In the end we had to knock the axle out of the birfs anyway do to a foul up with a grease needle. Sorry there's no pics of that, by that time it was late and I was getting irritated.
Kelly's only smiling because she has no idea how much easier the cleaning could be with the birf apart.
I hope you don't mind the picture posting but it's all somewhat relavent and everyone loves pics anyway.
Also I did mine and my sister's at the same time by myself a few years back and also had no problems with breaking the birfs open.
