so a little unscheduled wheeling tonight as i did a loop route and came back on a logging road marked on the map as a mainline, but actually a rocky deactivated glorified atv track with some very steep downhill switch backs. i maybe took them a little quicker than i should as i was late for supper.
after i got back on pavement i noticed a wobbly pull to the right and assumed something stuck in the brakes. when i stopped there was a smell of burning oil/rubber and my right knuckle is giving off mild white smoke. I have a look and it seems to be coming out of the felt seals and is not the brakes. plus there is more than the usual amount of grease on the ball and also some has dripped off onto the tire. it is not the pure liquid stuff but definitely a bit more gooey than usual and i've never seen it on the tire.
so i am wondering, what would get the grease hot enough to smoke (no water crossings). I am thinking maybe a blocked diff vent has led to pressure that has blown the inner axle seal? or does this sound like a wheel bearing has given up?
