technically, a 35 will rub all the same places with or without a lift, if you havent moved bump stop spacers, because the tyre still travels into the same place with or without a lift.
35's will fit, with a 30mm rear bump stop spacer, and you can put 10mm under the front.
We use a shock with 20mm more front droop and 80mm more rear droop on these, and are currently designing a coil over front shock to work with the long travel rear,a nd some new arms, hoping to fit 37's, with "afew" mods![]()
I was wondering why no posts from you lately (at least in the hundy section)
LX470, and the AHC is still working fine.
