Big picture for P0401?
e9999
Gotta get out there...
Moderator
US
dammit, I came down with a case of the 401...
Had a quick peek at a few threads. Looked a bit ominous, especially for those of us with required smog tests. Fortunately I have about a year and a half before the next one.
May I ask whether the situation is usually solvable with some clever labor, time, and minimal bucks? Or are we talking likely nightmare sleuthing and beaucoup bucks?
IOW, what' the big picture for 401, to put things in perspective before I attempt to read 2000 threads about it?
I read a bunch of threads. Tried some vacuum testing. Decided to replace the modulator and the VSV (seemed to be the culprit most of the time), then decided to replace ALL the 3.5mm vacuum lines while I was in there. I had the original green modulator, so I knew the stock one was almost 20 years old. Got everything on Amazon. Local Yota dealership couldn't touch the prices.
Knocked most of the skin off my knuckles and hand trying to remove the VSV...so I just made a bracket and relocated it...
Here's original location...
Here's the bracket I made...
Here's where I re-mounted it...
Haven't thrown a code in 250 miles...:):beer:
put some premium fuel in there, IIRC I did that on an LX450 I had and the code disappeared after driving it around some
Mine was the VSV also, relocated it as above.
Check that first, it's the easiest.
Checking VSV for EGR easy way P0401
mine tested bad, replaced it... still throws a code :( found the passage through the intake casting seemed clogged, bypassed that.... still throws a code :(
also, i replaced my EGR vacuum modulator
all that's left to replace is the actual EGR valve...
There was someone else within the past month or two who posted up that when he switched to mid-grade gasoline the P0401 went away, and then after he filled up with regular gasoline it came back. Then again when he filled up with mid-grade it went away a second time. Same as arcteryx mentioned above. So coincidence or something new in how the EGR system and ECM work relating to when the ECM sets the P0401?
What I don't understand is how could the octane rating of the fuel be involved in setting an EGR code, either correctly as designed, or erroneously, a programming glitch in the ECM maybe?? IDK
Assuming the other components of the EGR system were operating correctly is there any way the octane rating of the fuel could affect vacuum or the temperature that the EGR temp sensor was seeing? Could it be related to what the knock sensors or O2 sensors are sending back to the ECM and the programming of that??. Need some engine/ECM gurus to chime in.
I should add, I went to premium immediately, but found that mid-grade would work as well over a few tanks. and going back to regular did generate the code. I'd like to know the correlation too.
so the code went away on it's own? i didn't think that worked that way with the P0401
that'd be interesting to try instead of just resetting next time i gas up...
i'll try it, i've never put anything but 87 in it....
its been 1.5-2 years ago..... as I recall, I cleared it a couple of times initially as I was troubleshooting, but the fuel change did cause it to go off by itself.
VSV failed open circuit on mine. Was intermittent for several years prior (would come and go) until 100% failure. Fuel in this case would make no difference, given mine is SC and always on premium anyway....
e9999: Go through the obvious tests and clean outs and replacement of old vacuum hoses etc. It's all maintenance that should be done anyway at the vintage of these vehicles.
I guess we now have 2001 threads, since you started this one. Way to go :)
cheers,
george.
If Cali only does the OBD scanner hookup emission testing without doing the tail pipe sniffer, I wonder if the OP could away with bypassing the shoot n match and a $1 resistor?
Tailpipe, OBD, visual etc in the Bay Area...
cheers,
george.
Can a leaky exhaust cause a P401? I have had the code for almost a year now, but just keep clearing it. My "new" exhaust is leaking at a few of the joints.
Presumably the KEY sensor input that is used to decide whether the EGR is operating correctly is from the temperature sensor at the rear DS of the intake manifold. Too hot or too cold versus what the ECU thinks it should be will be posted as excessive or insufficient EGR.
So, small exhaust leaks should not enter into it unless the exhaust manifold has fallen off...
cheers,
george.
unfortunately, I'm in California so they will/may check the system to look for mods. That limits options.
On the (temporary?) plus side, the CEL went away on its own. Is that a good sign or just an indication that the truck intends to play games and win while making me suffer in the process?
Stop slacking and do some maintenance, isn't that what 80 ownership REQUIRES?
Like I wrote above, my cel would come and go (sometimes for 6 months or more), eventually came on solid with the EGR VSV going open circuit. The EGR system is NOT that complex *IF* you go through all the debugging steps. No one will be able to fix it for you with more internet chatter :)
cheers,
george.
Perfect timing. I just replaced both O2 sensors because of constant P0133 and P0130 after clearing many times. Now I'm getting P0401 multiple times and I have to do the smog in 3 months. I've read a ton of threads and here's what I gather...
P0401 = EGR Flow Insufficient Detected
Probable causes:
1. Blocked or clogged ports in the intake manifold and throttle body
2. Bad VSV for EGR
3. Bad EGR Valve Modulator
4. Bad EGR Valve
5. Loose/cracked/disconnected PCV or vacuum hoses
The FSM has specific steps on how to troubleshoot P0401. Some people do the shotgun approach and replace hoses, EGR valve, EGR modulator, VSV for EGR, and clean ports.
Others troubleshoot the problem and fix the root cause of the problem which seems to be 1 and 2 above.
I can't clean this myself, so I'm looking for a good FZJ80 mechanic in the LA/Long Beach area that can do this for me.
I'm attaching diagrams and photos from others who posted on this forum. I couldn't post the FSM pages on troubleshooting the P0401 due to the file being too big.
PCV = Positive Crankcase Ventilation
PCV Valve = First component invented to help reduce hydrocarbon emissions, to help keep internal engine cleaner, and prolong engine oil lifespan.
EGR = Exhaust Gas Recirculation
VSV =Vacuum Switching Valve
cheers,
george.
Actual maintenance...???? I'm trusting that if I post enough about it it will clear on its own for good! After all, this is the Internet age, isn't it? Isn't that how it's supposed to work nowadays? As a matter of fact, I posted once about it here and it cleared already. So there! :cheers:
It'll be back
Mine would turn up for a few days, disappear on it's own for months, return, disappear and finally return permanently. ~20yr vehicle, time for you to do some physical maintenance versus internet :deadhorse:, otherwise I'll point the bone at your HG :skull: (Kurdaitcha - Wikipedia, the free encyclopedia)
cheers,
george.
