BG Oil
As I said"good range"for motor oil. Didn't specify what brand i.e. Porsche(I own two right now on Castrol 10w30)BMW brand, and ACEA is in Europe not here. Thanks for playing,I'm out of this one.:grinpimp:
Ask him the following:
1) How exactly was it "bench tested"?
2) What Group of Basestock's does BG use for their "sythetic"?
3) How do they come up with their proposed interval?
4) Is the oil API rated? Is is ACEA approved A5 or A3 (and if so which one)? Is it approved as BMW LL-01 or LL-04, MB 229.5, Porsche OE, or and of the VW standards?
I'm going guess the answers to above are I don't know and no. Stick with oils developed by companies that have a lot of experience like Mobil, Shell, Chevron, etc.
Actually BG has some pretty cool stuff that works quite well. That does not mean that they are pre-disposed to peddle a good oil but it is probably fair stuff.
I will check with our BG distributor and see if I can get hard data from him.
Hmm, so since the ACEA specs, which are more stringent than API specs, are European, just ignore them. It appears that you are also ignoring Porsche's own requirements, as they do not spec 10w-30 as acceptable except in temps below 40f. Glad your not working on my cars. Do you do all your customers the favor of simply ignoring what the manufacture specifies because you have haphazardly decided that the API's general guidelines (where they specifically state to follow the manufactures recommendations) are better, or only for your own cars?
I agree w/ Cdan on the BG stuff. I use alot of their products from time to time but haven't tried their motor oil. I use the A/C compressor oil in my retrofits for the most part.
