Better fuel mileage?
Bend, OR & Dallas, TX
Ok. So I got gas yesterday at Chevron. $20 at $3.79/ gallon is roughly 5.277 gallons. I went from Madras to Wal-Mart in Redmond and back, a trip of 52.6 miles. Was a little over empty when I got gas. When I got back to Madras the fuel light was on. By my calculation I am getting between 9 and 10 miles per gallon. This can not be normal. What can I do to get better fuel mileage?
I like how you say "roughly 5.277". Someone is going to tell you to get a Prius, or a corolla. The fsm has a list of things to check and the air filter is at the very top. Also, tire pressure can have a big affect on economy.
First you need to refine your method of calculating mpg. Fill it it, run it till the fuel light comes on then fill it up again at the same gas station, preferably the same time of day and same pump and then do your calculations. You're
guessing you used 5.whatever gallons but you have no idea what was actually used. Also make sure that you adjust for a change in tire size.
With that said and done if 12-15 isn't accetable to you sell it and move on.
You should be getting better mpg than that, check your math and/or start your PM's.
Driving style is a big thing to. But getting 10 in town isn't out of the question even for rig that is up to snuff
For 1FZ that sounds low to me. I have 3FE and drive exclusively in the city and get consistently 11.5 mpg.
I have a 93 sitting on 33" BFG's with a 3" OME J spring lift. 7,000 feet altitude. ( with a steel roof rack, basket, and RTT mounted wide-ways for a rear facing anex.)
10ish to 11ish mpg in town.
13ish to 14ish highway at 60 to 65 MPH.
12ish on highway at 70-75ish MPH.
I've sliced and diced and jumped through hoops and tried like the dickens to improve MPG too.
Advice? Stay off the skinny peddle, keep rpm's low as you can, stay on top of maintience, use full synthetic fluids in all gearboxes, (you will notice it getting better mileage and making less noise and coasting better downhill. I kid you not. ) and find some ethanol free fuel. There are those that will say I'm nuts, but i know the truth. Ethonal free fuel gets much better mileage. (10 to 15%). Worth the extra cost at the pump for sure.
But I feel your pain. I've recently put "Clifford" in storage. She only comes out for expeditions and heavy weather my 93 4x4 pickup cannot handle. And when I'm lonely. Using a top heavy 6,000 pound triple locked Rubicon quality zombie crusher to take my daughter to choir practice might have been overkill all this time. Maybe.....
I'm getting ready for a Prudhoe Bay trip, maybe Tuk, maybe both in the next couple summers so I'm banking my 80 series ju-ju.
I get between 10-15. Sometimes down to 9 if I'm driving it hard and in tons of stop and go traffic
Mine gets 10-12 depending, on 265's. It's a cross I gladly bear, since I know I'll always get there. And back.
clean your mass air sensor go to the parts store and buy the correct cleaner. should add a couple of mpg.
i get 17.3mpg/13.6lper100 on highway wich i think is awesome...and 12.38mpg/19lper100km around town...auto no mods all standard.this is my second cruiser the last one i had was a manual and it seemed to get about 17lper100 everywhere..it did have 35inch tyres but
Sounds like you need to do an engine swap and get that new Prius engine :)
At 9mpg, you're driving it like you stole it, go you. Otherwise, consider what you're driving, anything above 10mpg and you're not driving it right :deadhorse:
Just did a 700mile trip and got 14.5mpg in my '95 with a running weight of 6800lbs on 33" dura-trac's, up lots of hills in +100* weather. I usually average about 12mpg with mostly city driving and short runs on the freeway. I try not to go over 70mph, but live in LA county where the posted speed limit is 65mph and everyone drives 80+mph.
The only way to get good fuel mileage in a cruiser is to keep it parked, and we all know how difficult that is to do.
You will get a lot of advice/opinions re: fuel mileage here… What most others have mentioned; fill up and drive until light comes on and then calculate. I am sure you know that these critters are not fuel efficient. There are things you can do to eek out a few more MPG's such as, tune up w/ OEM parts and that means everything from plugs/wires, oil changes, vacuum leaks, etc, etc to breaks not functioning properly. One thing that I noticed when I was driving our 80 more often (before the 16 year old took over recently) is keeping my RPM's below 3K. It really did help...
I have found that unless you average it across multiple tanks (e.g. 5 full tanks average) you can't really figure out what your mileage is.
Good luck,
Muddy1
My fiendish plan is that when my engine finally gives up the ghost, I will look at sourcing a diesel engine in there (and maybe put a manual tranny in as well!) That should get the MPGs and smile-factor up!
Muddy1
