So, just an update on the work we have done to my 92 LC. We adjusted the timing, changed the fuel filter, adjusted the valves and did a Seafoam treatment. Took him for a drive, came back, re-adjusted the timing and the valves. The main issue was that I would hear valve chattering at about 1500-2000 rpm, cruising speed, that went away when you accelerated past that point but came back again at the cruising speed. The truck also seemed more doggy than it should.
We also changed the oil and put in 20w50 oil and Lucas engine oil treatment. PO had used synthetic oil. After both valve adjustments, still had a little chatter, but after the oil change with the Lucas, it went away, for about 20 miles, but the sound came right back. Now, the cruiser definitely runs better and has better pickup, but, the valve chatter is disappointing. Any ideas? Short of driving it a while and possibly re-adjusting the valves again?
By the way, valves were definitely quieter after adjustment as well.
