Kevin,
Got the fan/shroud in today and here are the measurements:
22.5" w
15.5" h
6.5"d
These measurements are of the fan and shroud itself, without any mounting tabs or the bracketry associated with the relay.
The fan housing sticks out further than the shroud at the top and bottom: it is 17" dia.
The depth measurement is the total depth from the front edge of the shroud to the back of the fan motor. It might be slightly off, I was eyeballing with a ruler stuck between the blades. The shroud itself (without the fan or fan housing) is 3" deep.
If you're running out of room depth-wise, it looks like you could trim at least an inch off the front of the shroud and still have over an inch between the fan and the radiator. Not sure how this would affect cooling efficiency.
If you need any more measuring, just let me know.
BTW, cool project! That tub makes me drool!
JW
22.5" w
15.5" h
6.5"d
JW
