Best spot weld drill bit?
Quite seriously the best one you can buy. I use a very high end bit from an industrial supply store, but couldn't tell you the brand right off. Money should be no object. I think they're around four bux each. You might be better off with a dedicated spot weld cutting tool from a auto body paint store.
I used a Harbor Freight spot weld remover bit. It is a spring loaded pilot with a 3/8" hole saw around it. The hole saw lasts about 30-40 holes and then you have to flip it and use the other side... You get a total of 60-80 holes per bit unless a tooth breaks.
Only secret I have is to pre drill a hole for the pilot tip. Harbor freight also sells 7/64" drill bits in packs of 10 that were are perfect.
Let's just say I am up to 6+ spot weld remover bits and 40+ drill bits (they break easy if you lay into them). :doh:
I picked up a carbide hole saw from partsmaster. You can find them at other places like MSC. I have taken the whole truck apart with no trouble.
I picked up this for $60. I figure if it can get through 1000 welds I'll be money ahead.
