Rookie2 said:Rick,
What's the grinding kit for... cleaning off the head/gasket I presume? How could you tell whether or not the head needed to be machined?
If I understand correctly, the replacement gasket is a improvement over stock, and hopefully cures the problem?
Rookie2
Rick explained the purpose, I'll clarify the nomenclature:
There are Two basic gasket sets or kits used in engine repairs. One is a "valve grind set" and the other is an "overhaul set". The valve grind set is also refered to as a "top end" set and the overhaul is sometimes refered to as a "complete" set. As Rick stated the valve grind set consists of the necessary gaskets and seals to remove the head(s) and grind the valves. An overhaul set includes all of the above plus the additional gaskets and seals to do the "bottom end" of the engine. It is important to note that these gasket "sets" sometimes do not have everything you may need to do a particular repair and will likely have some stuff left over when you are finished. Kits are generally cheaper than the sum of the individual parts.
D-
