Local dealer wants $275 for just the OEM key. Any idea where the best/cheapest place to get an OEM key fob is? Are there any aftermarket fobs that are trustworthy (will last a long time)?
What year? I think since mine is a 2000 its a lot more difficultI had a valet key and the local key guy was able to program and sync a remote for me. I bought a remote key off ebay.
this was on a 98What year? I think since mine is a 2000 its a lot more difficult
US 2000MY had standard keyless entry. Pre-facelift models like yours are fully DIY programmable using the “chicken dance” method. If a locksmith was unable to do it, they’re either doing it wrong or your blank’s transmitter is incompatible with the vehicle.2000… thinking I definitely need an ECU reprogram as the dealer told me the only thing they can do is replace the ECU (discontinued part of course). Other thing I’m curious about is whether keyless entry was standard in the 2000 model. I thought it was, but this evening a locksmith wasn’t able to program the keyless entry so I need to confirm.
Even if the key used in the ignition is a sub and not a master? Thinking either that was his issue or weak door lock actuatorsUS 2000MY had standard keyless entry. Pre-facelift models like yours are fully DIY programmable using the “chicken dance” method. If a locksmith was unable to do it, they’re either doing it wrong or your blank’s transmitter is incompatible with the vehicle.
I don't understand your question, and maybe I don't fully understand your scenario. Here's what I have learned, having made a couple of keys for a Toyota and Lexus:Even if the key used in the ignition is a sub and not a master? Thinking either that was his issue or weak door lock actuators
Thanks for the help, I really do appreciate it. I only have valet keys so an ECU flash seems to be my only option to get a fob. Locksmith that came out last night (although very nice and didnt charge me anything) wouldn't go any further as he failed to program the lock/unlock first (which makes sense as there was no master available to program it). Might just live with what i have depending on how much a flash will cost. Again, thanks for all of the help.I don't understand your question, and maybe I don't fully understand your scenario. Here's what I have learned, having made a couple of keys for a Toyota and Lexus:
- There are master keys and valet keys. The master typically has a head with keyless entry buttons, the valet does not. On a Lexus (and maybe some Toyotas?), the valet blade is slightly different from the master blade so that the valet cannot be used to open the glove compartment.
- All keys contain an RFID chip that disables the vehicle's immobilizer by proximity to the ignition switch. You are programming the vehicle's ECU to recognize the RFID chip, not programming the key itself.
- Separately, a master key has a wireless transmitter that must be registered to the vehicle to lock/unlock the doors using the buttons on the key head. Again, you are programming the ECU to recognize by the key's transmitter.
- Earlier Toyota key blades are edge cut: the 'ridges' are on the outer edge of the blade. Any basic hardware store that makes keys can cut these. Lexus and later model Toyotas are 'security cut': there is a squiggly channel down the center of the blade. These require a special key milling machine that any good locksmith will have. These are also mistakenly referred to as 'laser cut.' There are no lasers involved in cutting them.
- The wireless transmitter's frequencies have varied over the model years and you must have a blank that transmits at the right frequency for your vehicle. The blank's FCC ID (printed on the case) is your clue about the frequency. Cheap blanks sometimes don't have a printed FCC ID, so it's hard to tell if they will work. I believe the RFID chips are universal.
- The ECU will know the difference between a master and a valet, and how many keys of which type are registered. It stores them in different 'slots' in its memory. This is limited. Once you run out of RFID slots, you cannot program any more, and you have to clear the ECU's key memory (DIY-able). Once you run out of keyless entry slots, the ECU will over-write the oldest ones (so the keyless entry of the first master key to have been programmed will stop working).
- A master can be used to help register a new valet. A valet key is lower-order in terms of security, so it cannot be used to help you register a new master.
So, if 1) you have a wrong-frequency blank, 2) your ECU's key 'slots' are full, 3) you're trying to program using a valet, or 4) you're doing the programming procedure wrong, you'll fail.
Hope that helps, and maybe the key gurus here can check my assumptions above.
