Slee CDL switch. Took 10 minutes to install. Works awesome!
Fixed! hat happened was that I burned the relay trying to start the truck when the Air Flow Meter went bad, I thought that the ignition switch was bad. It wasn't the switch, it was the relay. replaced the relay with an Ford OEM, and back to normal.I'm using a Ford starter relay on mine, I wired mine to the 2 large posts, has to be careful, the truck will start in any gear! If someone knows which cables to connect under the dash, let me know please.![]()
Installing a "You left your headlights on" warning buzzer.
3.49 from Radio Shack, 10 minutes to install.
Borrowed the idea from 60 series tech:Best mods for under $50.
Thanks, Dynosoar.
JJ
Thanks, Dynosoar.
JJ
A buzzer's not really necessary on an 80, is it? My headlights shut themselves off when I take the key out of the ignition.
My '91 headlights don't turn themselves off.
Left them on in a well-lit parking lot a couple of months ago.
JJ
was two and it really made my life so much easier. 1 how to make a aux tank for 100$?
2 where to buy HIR bulbs? i`ve mailed danielsternlightning.com but no response yet.
