Best method for cleaning block deck
Kansas City
I searched, but...I apologize if I missed something. I am getting ready to start the HG job on my 95 1FZ and want to be sure I do this properly. I have heard mentions of scrapers, razor blades, and chemicals to remove the old HG from the block. I do not want to chance messing this up, so is it general consensus that using a metal gasket scraper and/or razor blade on this surface is fine? Is BG44K/brake cleaner/similar good to finish things off with, including the top of the pistons? Is alcohol good to prep the surface? I really want to become an expert on this topic before I do it; I don't want to have to be in here (the engine) for quite a while once it's buttoned up.
Thanks for your ideas!
Read this post, the young man Is 18 and did a remarkable job. Many answers to your Questions. Good Luck..!
Head Gasket job (total noob)
He rceived much attention from the members here, deseredly so. There Is a wealth of Information attached to that post and you should have all your queries answered. Good Luck..! I am sure he would love to give back by helping you as well.
I do it like this
1 scrape off old gasket with scraper
2 use brake parts cleaner
3 after gasket is off I scrape and clean Pistons top , brake cleaner and scrape
4 mini die grinder on air with. Red 3m disc to polish everything back to new
Ps I plug the oil galleys there is two with rag to keep it from getting bs in it and plugging it
