I don’t have remote start so I can’t try this but I understand that some Toyota’s can be left running if you lock it with the mechanical key. Why doesn’t someone with remote start try this, just to satisfy my curiosity?
I was referring to this w free shipping w coupon:
2014 Toyota Land Cruiser Remote Engine Starter - PT39860140 | Roseville Toyota, Roseville CA
Have your vehicle’s interior ready, waiting and comfortable in any kind of weather.. Use your Smart Key fob to start or stop the engine. Activates preset air conditioner, heater, defogger, defroster and temperature settings when engine is started...parts.rosevilletoyota.com
I occasionally start my truck like this and then go back inside. I don't bother to lock it - if you put your foot on the brake to try to shift out of park it will cut the engine off. You might be able to pop it into Drive with a screwdriver on the repo-man bypass, but I don't think you'd get very far unless you only used the ebrakeI don’t have remote start so I can’t try this but I understand that some Toyota’s can be left running if you lock it with the mechanical key. Why doesn’t someone with remote start try this, just to satisfy my curiosity?
The part # and link you sent above is for the 2014....will that same part # work in a 2010 LC? And when I try the link, I get an auto message that the site is closed...kind of strange. Any way, I appreciate everyone's help here and I'd prefer to stay with OEM as long as isn't cost prohibitive. We get really hot, humid weather here for 6 months a year so I need the remote for cooling down my charcoal interior. Thanks..
If you just lock it and leave it running .. someone can just drive off with it.
How would someone drive off with it? If you push start, and then take the key with you when you exit the vehicle, the vehicle will shut off when someone depresses the brake pedal if there is no key in the vehicle.
In fact my wife and I found if you start the vehicle with only one key inside then swap drivers and keys with the engine running, the truck will still shut off even though there's a key in the vehicle because the key was not there at startup time. That said if both keys are in the vehicle we've found one of us can get out and the other can still drive off, so I assume any keys inside the truck sync with the ECU at startup.
I've not tried it but I suspect if you left the window open and did a remote start, then climbed in via the window that depressing the brake would also shut the vehicle off even though the door was never opened. In short unless there's a key fob in the vehicle someone cannot drive off as they cannot apply the brake to shift from Park without the engine cutting out.
Yep that's what I'm talking about - use the fob to start the truck, then take the fob out. In my 200 the engine cuts out if there's no key and you hit the brake. Last year my wife dropped me off and home and I went inside with my key in my pocket. She put her foot on the brake the the truck shut off... she had forgotten her key so there was no fob in the vehicle. Try it with your 200.The question was if you start it normally and lock the door, not remote start it.
If you remote start it .. then it will turn off... however if you start it normally then lock the door and walk away .. someone can just drive off with it.
I have done with it another vehicle .. not the 200, and not using the remote start. Try it. Start the vehicle with your friend in there .. then have your friend walk away with the fob.. usually makes a ding sound .. then try and drive off. Worked for me. ... So it you just start it and lock the door .. you can drive off with it, especially if you do not trigger some alarm. I have not tried it with the 200.
Hmm, so I tested this on Sunday and you are right, the engine did not cut out. Which is really odd because it most definitely did for my wife when I walked away with the key and she was in the driver's seat before. Now I'm curious under what circumstances the engine cut off for her, because she was very confused when it happened. She definitely did not use the remote start because I was driving and exited the truck...I'll test that tomorrow on the 200 .. .. on this other car we have you can drive off with it if you do that.
What I did find out today was .. If you start the lc200 and walk away with the fob.. and the person inside locks the doors .. you can not get in using the fob even if you press the unlock button .. you need to either get that person to unlock the door .. or use the hard key.
I'm not sure what that comment is suppose to insinuate but my alarm, (one for the directed brands) was installed no problem without the help of a dealer. .. Just saying.
