I recently installed a slee 4" kit on my 80. When it came time to install the rear control arms I grabbed one of the sleeves that go inside the bushing, pounded it in, realized the bolt wouldn't fit because the diameter of the sleeve was too small. For some reason I didn't check any of the other sleeves, just installed the like you would install the shocks.
Called slee the next day and was informed that 80s and 100s use the same control arms and there was 2 different diameters of sleeves provided.
On to my problem. The frame bracket on the ds is now bent from installing without that sleeve. I can get the arm into the bracket but it wants to go around the outside of the install hole. I have tried pry bars, bottle jacks, pounding the 100 series sleeve into the bracket.... Nothing is working for me so far. I am sure there is some easy way to "widen" that bracket but I have had no luck so far. Anyone know of any ways I could try? Thanks.
