Bender build gets some junk in the trunk!
No squeak that I have noticed so far. Haven’t taken it on much rough surface yet though. A spray of silicone
Finally figure out where my squeaking is coming from. It's from the latch, when it's engaged. The 'tongue' of the latch sits in a slot on the frame of the drawers when engaged, and it's this contact between the 2 metals that causes the squeaking. I confirmed by putting some duct tape on the metal tongue and this stopped the squeak. Just have to find a more permanent solution, but it's duct tape for now!
Duct tape solution # 1 million and three! 🙂
Congrats on a solution.
Can you adjust the latch so there's tension between the latch and tongue? Just a wee bit of tension of the latch pulling on the tongue is all it would take to mute the squeak.
If I'm imagining your setup correctly, put a rubber bumper on the very back of the drawer so when it closes, it presses against the rear of the drawer cavity. Doing this will require you to give just a little push to engage the latch when closing, now there's tension on the latch.
Yeah, good idea but there is already plenty tension on the latch. When you turn it to engage, it actually pushes up against the latch and tension holds it in place. Which is why the duct tape is not a permanent solution, it will rub off eventually as it scrapes against the latch.
  • Like
Reactions: r2m
Sure, I just took off the plastic covers for the two pockets in the swing gate and used those for templates. Plywood, piano hinges, some cable I had laying around from putting up some sail shades on my patio, and some random nuts and bolts from my giant box of bolts that have come off the rig. I think the only thing I actually purchased specifically for the project was the piano hinges.
The cable attaches to bolts that are backed by some very large diameter washers so not to pull through.
The latch is super simple. Just some aluminum angle, cut a notch out to slide over a bolt
I am still looking for the right material to surface it with. Thinking some kind of plastic. Gonna put some leftover black carpeting from my second row cargo area project on the bottom side.
No squeak that I have noticed so far. Haven’t taken it on much rough surface yet though. A spray of silicone View attachment 3181398View attachment 3181399View attachment 3181400View attachment 3181401
Just a suggestion, you can get vinyl covered cable. Eliminates any abrasion
Personally, I can't justify wire cable any more, considering all the benefits of synthetic line and now that prices have come down, it's even more of a no-brainer.
Agree 100%. I thought you were committed to wire cable for some reason
  • Like
Reactions: r2m
Had wire on the overlander I built before my last one, and boy did that make the front end that much more heavier! Albeit, it was a 15,000 lb winch on an F350 crewcab.
