To start, I must credit @4Cruisers for introducing me to the idea of combining the later F-engine type of throttle ('bellcrank' plus a cable-type throttle pedal) with the later 2F-type of air cleaner assemblies and a ball-joint carb throttle, which is native to a ton of Aisan and Aisan-clone carbs out there. This would be a hot idea for anyone trying to rehab an FJ40 with a hacked up history, installing a 2F carb without modifying the firewall on an earlier rig to support the linkage bracket, or finding a better solution than addressing mechanical slop at every point along a torque-rod accelerator linkage. The bellcrank principle might me a cleaner install for carb conversions as well.
Below is the original carb, manifold, spacer, from my '75 FJ40 fitted with a cable-bellcrank setup. Technically speaking, I assume this Toyota part# 78106-90351, correct me if I am wrong, but, a MUD search comes up with one that has the return spring configured differently (toward the front of the truck).
The goal of this project is to duplicate the above bellcrank and ball-joint push rod. The original Toyota part has some wear, and I'm more interested in a no-slop, positive feel on the gas pedal, and a stack of my own fresh bellcrank clones.
Below, torque-rod-type linkage set-up from early '75 2F tech.
