Before I tear transfer case apart...
Salem, UTAH
Viscous coupler... Who needs it anyway
I am making the preparations to tear apart the t-case and buy ($ouch$) and replace the viscous coupler...
Before I do this is there any way to determine if possibly the CDL is just not behaving as it should?
I do not have CDL switch. When shifted to Low, ABS and CDL lights come on as they should and go off when they should. I can hear the CDL actuator when the shift is made. With one wheel off the ground and tranny/H-L both in neutral... the wheel has a little play, but it will not turn.
Is it possible for the CDL to actually be 'stuck' locked, despite the lights saying it is not???
I am 98% sure that the viscous coupler is seized, but don't want to shell out the cash for the new part if there is something else to that could be the culprit.
did I mention I have had the truck less than a week, here's the story...
https://forum.ih8mud.com/80-series-tech/205978-got-cruiser-finally-yes.html
Thanks, Hal
I know that the VC as well as the axles can get "stuck" in the locked position. However, I do not, at the moment, recall how to test for it. If I remeber right it takes a multimeter and testing the plug for voltage and some other stuff. I think at the point where you are it would be just as easy to pull the VC and see if it's bound up. Sorry I could'nt be of more help this time. I am on some good meds and not thinking too clearly.
The VC itself has no electrical components, as far s I know. It's strictly a mechanical/friction device.
Sure sounds like you're on the right track to me.
I wouldn't buy the replacement VC unless I knew I could return it if not needed, or until I tore into the TC and knew 100% that that was the problem.
Also, don't forget that you can simply remove the VC and run without it if you so choose. (Yes, he'd still have a center diff and the capability to lock it, for anyone wondering about that.)
Curtis
Funny story...One of many durring my drive from KY with my newly purchased FZJ80...
Mine felt like it had a bind when I would come to a stop , At the time I had no idea what it could be, I drove 1700 miles home and It never occurred to me that the VC could be binding, Later on I was cleaning the TB and got on the front of the 80 and heard a springy ping(the CDL light had been on for a few miles, After I tried it out) checked the dash again and it was off.
What Im getting at is it may be like the Diff locks on the axles, They may need a bit of exercise.
Just a though.
Good luck
Edit..
IH8MUD.com Forum - View Single Post - New guy with a few Q's
Enjoy :)
You could put the 80 on jacks all around. Put the 80 in gear and give it a little gas, then apply the parking brake. If the CDL is off, the fronts should spin and the rear should stop/slow. If you lock the CDL then applying the parking brake should cause a slowing at all fours.
Just a guess.
I think the cdl motor on the later models is the same as the one on my 92. If so, You can lower the trans crossmember enough to reach the 6 bolts that hold the cdl actuator motor off of the top of the transfer case, I would check the motor first and see if it is engaging. It is a simple gear that moves the fork to move it from locked to unlocked.
Before I dropped the transfer I would check and make sure that you can cyle the shift fork manually, If you can not mover the shift fork then you know the vc is toasted.
Dave
I might be having a issue with mine also. Is it pretty safe to engage it and drive at hwy speeds for a few miles? The section of road I plan on running is pretty straight.
Just a guess.
That's why he jacked up one wheel. One wheel will spin freely if nothing is locked/seized.
Curtis
No,
Unless the axle differentials are locked, the axle differntials will allow one wheel to spin freely if all others are on the ground.
If you remove the actuator motor from the top of the transfer case (you can do this with the transfer case still hooked up to the drive lines) Once the motor is removed you will be able to see with a mirro or feel with your hand the geared shaft that moves the shift fork, If you can not move the shift fork then you know that the engagement is fouled and you need to drop the transfer case and investigate further. If you can move it and the motor is not actuating then you can isolate the issue to the motor or subsequent wiring. There is a relay for the cdl motor behind the drivers side kick panel. There are several tests in the fsm for the actuator motor. I would not recommend that you hook 12v raw up to the motor, I do not recall the amperage limit for the motor but I tested mine with a 9 volt battery and was able to get the motor to engage in either direction.
I fought with mine for a while. Had it working with a new motor breifly then it died again.
Dave
:hhmm:So... Tuesday is disassemble and diagnosis day.
Decided that it will better to thoroughly check it out before shelling out the $$$$ for a new VC and then possibly have to return it (20%restock fee $$$).
:bang:It doesn't seem like there is another way to be positive of the VC or the CDL linkage someplace.
I'll try to take some pics of the process to appease the curious natives.
Thanks again!
Right, but how can you tell if it's the VC (seized) or the CDL (locked & stuck)? The results are the same...
The actuator is a simple motor driven gear. It's possible that the motor is "stuck" in the locked position. I would crawl under while someone locked and unlocked the CD and listen. You can also pull the motor assembly off the top as mentioned in a previous post. You can lock and unlock the CD by spinning the drive gear by hand.
If you really need a VC, chances are that someone else might have an used one when they went to the part time kit. Just a thought...
