Before I tear it down…
Are the roller bearings really tighter in terms of tolerances? If that's the case it makes me think that Toyota went from bushing to bearing with the shift to ABS, to keep the gap more consistent on the sensor/ring, though I haven't really heard that before. I prefer the bushings for durability and how they will behave if run to failure but I do get a bit of ABS activation on bumps sometimes and this makes me wonder if I've introduced excess play by shifting to bushings in the spindles. Anyone have similar or contradictory experience on this topic?
Anyone have the inner diameter specifications of bushings and bearings?
I think ABS started in '93 and they went to the roller bearings in '98 with the 100 series but someone correct me if I'm mistaken. The bronze bushing does a find job for what it was designed to do but the roller bearings gotta be so much better. Prolly helps with an incremental improve with fuel economy due to less drag, not these things are in any way excel in that dept :)
I'm almost certain that some of the later 80s had the roller bearings from factory but that's from memory of reading on mud and not first hand experience. My '97 had the roller bearings when I got it but I don't know if they were original or not.
I agree on the likely benefits. After fishing out the debris from a failed/exploded bearing though I saw the appeal of the bushings and went with those. I'm sure the bearings exploded due to being run dry as my 80 was clearly not maintained well before I got it.
My ‘97 I bought in ‘00 came wearing brass bushes - I bet I did the 1st FAS even though it had some ~120K on it & IIRC it’s a 3/‘97 build.
Aside from minor upkeep, I was pretty sure I was 1st wrench on alot of hardware / full baseline before doing my stuff to it.
I agree on the likely benefits. After fishing out the debris from a failed/exploded bearing though I saw the appeal of the bushings though and went with those. I'm sure the bearings exploded due to being run dry as my 80 was clearly not maintained well before I got it.
+1 -Think Slee was of same mind / I went in w/ new birfs (full new FR axle swap-in) -brass just seemed the sturdy / no extra parts way to go.
