Bearing Preload and Knuckle Alignment
"the whale's vagina", CA
Hi,
I have read I think every single post out there on front minitruck conversions and am about to build up my front axle on my fj55 build. FYI, I am swapping the minitruck axle knuckles onto a 1970 FJ55 landcruiser.
What I am confused about it bearing preload vs. knuckle alignment. a link here:
http://internet.cybermesa.com/~chscully/front_discs.html
I am confused as why the knuckle needs to be aligned on the axle? Is this necessary? I have been told by other that I may simply swap over the shims that were on the minitruck axle in the exact same configuration and the preload and alignment should be fine. I am not looking for perfection so if others have simply swapped over shims and not had to use fish scales and other tools to get this done I would like to hear from you. To me the knuckle alignment and the preload seem to be the same things as they are adjusted the same way, by adding or removing shims?
Basically I need to know if I am ok and correct in the thought process of simply swapping over the minitruck shims exactly as they were sitting on the minitruck housing over to the landcruiser housing. I have marked the shims exactly as they sat when I took them off so this should be easy. Thanks for everyone's help on this.
Noah
The shims do two separate things:
1. they set the preload on the knuckle bearings. You can set the preload with a fish scale.
2. They compensate for manufacturing tolerances in the knuckles and the axle housing ends to center the axle shaft concentric with the inner axle oil seal so that it doesn't leak. The facctory SST accomplishes this.
Just picking the same shims that came with the knuckle will not help to compensate for manufacturing tolerances on the axle housing ends. Most people just end up guessing about which lower shim to use and hope they get lucky and the seal doesn't leak.
Thanks Pinhead! great description. Yes, I think I will just swap over the shims and hope for the best. If it leaks a bit later on I am not worried too much about it. My FJ40 knuckles leak a bit and it has not really caused much of an issue so far. I sure others will disagree with me. :) I may find myself a fishscale and at least make sure the preload on the bearings is correct.
What I still don't understand from your description above is if the knuckle was not centered correctly but your preload is correct, wouldn't adding shims to center the knuckle properly then mess up your preload once again? It would be common sense that you couldn't accomplish both unless you got very lucky. Sorry if I am overthinking this, just curious.
Noah
Noah
No. When you add to one side to to center the axle, you subtract the same amount from the other side to keep the preload OK.
If you use the SST, it takes the guess work out of it.
