? bearing is this ?
Tucson / Vail, AZ
Website
kartchcustoms.com
In the maf tcase rebuild kit for a four speed case there is a bearing with a retaining ring on it. Where the heck does this thing go? I just looked up the part number. It is a KOYO bearing #70534. It also has 63/32NRC3 on it as well.
I don't remember pulling anything out that had that ring on it.
Thanks in advance.
Sorry about that, it's for a tcase rebuild kit. It's the same size as all the large bearings in the kit except it has a split ring that wraps around it like its meant to keept the bearing from going in to far.
The front output bearing is a ball bearing that has a snap ring to retain it, but the snap ring is not part of the bearing.
IIRC it is the same bearing as on the tranny output shaft, but maybe that is only for the 3sp case.
I'm wondering if i just got the wrong bearing. It's not a tapered bearing and the snap ring is part of the bearing. I didn't see this bearing until I was putting the tcase and the tranny together and this was the last bearing I had. I dont know what that bearing is called but it is the last bearing one would install when mating the two together.
I just went out and looked in my junk box and the front output bearing is a 6306, but that is a Nachi number and I don't know if it is the same as Koyo. There are only two ball bearings in the case: The front output and the tranny output shaft bearing and I think they are the same on a 4sp case.
That bearing should be the one that goes on the rear of the imput shaft [tranny tailshaft] in the transfer case. You will obviously need to remove the snap ring to use it.
Sometimes the vendor that packages the bearings just ships them that way. I have had this experience with some of the rebuild kits I sell as well. That is how I know.
Hth
Mark A.
Hth
Mark A.
Thanks so much you all. That is exactly where I'm at in the rebuild process. I went to install that bearing (rear bearing on tranny tailshaft) and it had that snap ring on the bearing! Man, I wish they would have included a note or something about that.
So all I need to do is remove the snap ring and install? Awesome!
I'll take a picture of the ring and add it to my tranny rebuild post so I can save somebody else the aggravation I went through thinking I got the wrong bearing.
Thanks again! :cheers:
