Beadlock Prefrences
Mike, I hope I'm not late to the party on this, but I'm starting to become more and more of a fan of production beadlocks like the Trailready HD slim rings or the Raceline Monsters. Those two wheels probably have the best reputations of any beadlock available right now. But the only the thing I don't necessarily like about having a wheel with an aluminum body is that you can't hammer out a bend in the wheel like you can with steel. My DIY locks have been OK, with the exception of slow leaks, pinch flatting, and a bent outer ring.
Last wheeling trip, one of my outer rings bit into the tire so hard that it sliced the sidewall in four places... not all the way through, but deep enough to require vulcanizing. I'll admit that it was entirely preventable- I was trying to bounce my passenger front tire over a tall undercut rock and taking about a 40 foot running start... Nothing new, just being my usual foolish self.
Knowing that my driving style isn't likely to change, I want to come up with a better solution for outer rings. I want a wider ring in general, to prevent bending (not talking about coning here but actually denting the ring in from hard side hits) and also spread out the cutting force (when the tire gets pinched) over a greater surface area. I've found a supplier that has sheets of .375" 6061 aluminum for a surprisingly affordable price. .375 6061 Aluminum rings are about 5% stronger than a .250" mild steel ring, and don't rust when they get hit. .500" thick 6061 rings are about 40% stronger than the standard steel DIY beadlock ring, and still affordable. This solution would also let me keep my existing steel wheels, that I can hammer back to (mostly) round again if it's ever needed. Since nobody in the industry is offering something like this right now, I need to track down someone who can take a CAD file and come back with some cut rings.
Also there's a huge difference between a staun and a real beadlock. The staun does nothing to prevent the wheel from bending on hard hits. Sure you can run wheel stiffeners, but they just add to your overall costs.
So to answer the question, all DIY beadlocks are pretty much the same and probably aren't the right fit for your customers, since they have to pay labor on the work that goes into building the wheels. And I think there is definitely a market for a DIY kit with a weldable steel inner ring and a "bulletproof" 6061 outer ring. I know a lot of people, including myself, that are disappointed with their DIY beadlocks.
Mike
Have you asked Will where the beadlocks I bought from him came from?
I think I paid him $70 a wheel and they are production 32 bolts. Granted, I'm sure they cost more than that new, but they couldn't have been terribly expensive.
They cost less than Cam's DIY's, and they don't leak. :flipoff2:
Thats a decision we all have to make. If you are unsure of your fab skills or welding ability by all means order up some production wheels.
I am confident in my ability to build my own beadlocks in order to save 100s of dollars.
I will take a craftsman's hand work over a machine built item anyday.
I would take a machine made production item over an amature mess though too.
I agree completely! However, most people are not a metal craftsman. I can hold my own with a welder and my DIY beadlocks leak... All of them! But that's not to say I wouldn't have a slow leak with a production beadlock.... I had slow leaks with non-beadlock wheels.:meh:
Ill be welding up a set of these badboys for my toyota this weekend. Ill take pics and do a nice install/build thread when done. I weld up beadlocks all the time for folkd and figured it was time for some with the shop name.
Im reviving this thread to ask about tires. This is the truck and is currently sitting on borrowed 38.5" SXs. The truck is running 30 splines and stock rear shafts.
We are also trying to decide between 15" and 17" wheels which causes its own issues. I love my SXs on the east coast but if you want to run a 17" wheel you have to step up to a 42 or down to a 36. You can get a 40" LTB in a 15 or 17 but I think they will be a bit big for this rig and its axles.
I also like the size of the 39x14.40 Pit Bull Maddogs which is available in a 15 or 17" wheel. The rockers are also an option but the 39s are wide which I dont like and the 42s are again a 1 ton tire.
Some how I keep coming back to a well grooved 38.5" SX but was curious if I was missing anything.
I've got a full year of abuse on my 39" Maddogs...and still love them. They've held up well to my driving and still impress folks with how they work.
Comparison pic: 37" tires on Texican's rig, 39's on mine...this is from this past weekend in TX
And I still like the bling look of the TrailReady 17x9's with the thinner ring :)
You are running a 40 width front axle w/ spacers correct?
