Mike -
I have two red tops and have had no issues. First off you have to keep the idle up when winching...if you can install a hand throttle...even better. The red tops are a starting battery...thus, if you drain them below 12.6 volts you are going to have a hard time starting. If you go even lower you risk hurting the battery, such as below 10.5 volts. The reason is that the lead "paste" in the batteries (used to produce energy) is consumable meaning the more times you discharge the less "paste" you will have. This means that each time a gel based battery not specifically designed for high recycling (charging) is discharged you decrease the ability of the battery to hold a charge. Therefore, you should use a yellow top for anything that requires deep charge depletion repeatedly. The yellow top is great for cranking as well but, does not provide the intense 5 second burst that the red top provides. You can also use the two batteries together as long as there is an adequate isolator used. There is a really good chapter on batteries in the managing 12 volts book...I think you have my copy...
