I purchased a red top optima battery when I installed my winch. Apparently red tops are not designed for a lot of winch use. I killed it when winching 62 to the street. I also had to have a reverse terminal battery for the 100 with the setup I have. I was looking at the yellow top but they do not come in reverse terminals. They have a yellow top 35 model that might fit but lost about 80 CCA from the yellow top 34 model.
What should I run with a winch with decent CCA? I would also like a sealed battery. The last one that was not sealed leaked battery acid every where after the razorback ramble and did a lot of surface damage to frame that I had to paint back.
