Battery Isolator question....
Traverse City, MI
Website
www.myspace.com
Im looking at a relay isolator right now (Stinger Part # SGP38) that is suitable "up to 80 amps". Is this cutting it a bit too close for our alternators?
Clint-
For a solenoid type isolator, I would recommend SurePower. Either the 1315 or 1315-200 (amps). You can get them from Interstate as well as other places if you search.separator
I know the sure power is a top notch unit, im just wondering If I may have stumbled upon a bargin here. I belive out alternators put out 80 amp (correct?) which is the limit of this relay. Since im not so quick with electronics, im looking for input on this unit....
In addition to how much the alternator puts out, you need to consider what the maximum current that will flow between the two batteries. For example: if you drain your main battery and then need to use your aux battery to start your rig, you will draw hundreds of amps through the isolator. If you plan on running a winch and have the batteries connected together, you will draw hundreds of amps through the isolator as well.
OK, thanks for the input. Based on that info I think Ill opt for the 200 amp version.
