Battery dying issue
Austin, Texas
So I’ve had an issue recently where my battery seems to not be getting recharged or getting drained by something.
I tested the Alternator and ended up replacing it and having the battery fully recharged about 1.5 weeks ago. Today, i go out to start it, it cranks the first time, but not enough to turn over, it fails. Second time... click,click,click. Great...
I noticed something on the alernator that I had a question about. I have a wire here that slides over this single “plug” looking piece, but only onto 1 of them. Is there a difference in these in which this should be on? I have had it on the bottom one and I’m wondering if this is a mistake. Electrical isn’t my strong suit so I am needing some guidance if maybe this is a different setting.
1939700
If it is a parasitic drain from somewhere, I am not sure where to start.
Just used a multimeter to test battery and alternator.
Reading 12.32v before starting engine and only 12.18v after starting?! Any thoughts? Is the alternator even working? The voltage shouldn’t be higher when the vehicle is running, I’m confused.
Not knowing anything about your setup this is definitely shade tree, with the ignition key off and everything hooked up loosen and remove the negative battery post clamp and lightly touch the loose cable end against the battery and look for a spark.
Do it two or three times to make sure.
If you get a spark start start unhooking things one at a time and testing each time.
If you have any clocks or sound system on do them right away.
At least you can fins where the bleed is coming from.
Like I said, don't know what alt you have but on the delco one post goes to the batt and the other goes to ignition switch.
Most likely the field is not being excited.
Show some better pics of the alternator and type.
Can't figure how a blown fuse would cause the battery go dead from sitting.
Exactly what is an engine fuse?
Fusible link?
The battery wasn’t completely dead, just not enough juice left to power the starter. It drained because the fuse in the panel labeled “engine” was fried - this fuse happens to be what the Alternator runs on. When I tested with the multimeter and saw the voltage with the vehicle running, it made sense. I have just been running on the battery life, the alternator wasn’t charging it. As soon as I replaced the fuse the voltage started rising back up to normal.
Meaning, my old alternator was probably never bad. It was likely the fuse this whole time...doh! Oh well, I’m not mad at new parts.
It might be good to figure out what caused the fuse to blow in the first place.
Trace the wires from the fuse, using a wiring diagram (like @GA Architect posted) and look for shorts, most likely insulation worn off somewhere. Also check the voltage regulator.
I figured the alt. was not getting the required volts to excite the field but never heard the term engine fuse.
As 1911 suggested, something had to cause the fuse to blow.
I think I may have discovered the problem...possibly. I drove around a bit this morning and it was working fine again for awhile then it quit charging again(noticed the amperage habits change while driving). Then I went and checked under the hood when I got home and discovered the wire that slides onto the F terminal had slipped off. Thus creating a short, right?
Thinking back when this all started happening before I replaced the alternator - I had noticed this same wire had slipped off and I put it back on. At this time, I didn’t think twice but I had probably ran it like this for awhile and was most likely when the fuse had blown. Kept driving it, ran into dead battery and replaced the alternator. With new alternator on and a blown fuse, the alternator was never excited, this driving around on pure battery power.
