Really, voltage drop across a fuse - a fuse has very close to 0 ohms resistance. You won't measure anything of any consequence and without knowing the resistance of the fuse you'll have no idea what the current flowing through that circuit is (V = IxR). Assuming most parasitic draw that causes a flat battery over a few days is of the order of hundreds of milliamps, explain to me the voltages you will need to be measuring across the fuse that would indicate some problem?? What is the resistance of a 10A or 15A or 20A fuse?
If you want to get really fancy then you would put a sensitive DC current clamp over each wire fed from the battery to each circuit. From what we've seen on cruisers, typical parasitic current draws are from alarm systems, radios and various after market stuff added on by the PO or owner etc.
The first step is to measure current draw from the battery, then isolate each circuit. Well proven and easy to do.
cheers,
george.
