Sure-It's a smart way to go. I have an extra fuse panel under the hood and one mounted under my front seat. Then you have plenty of safe circuits to run your electrical gear.
I specifically recommend Blue Sea fuse boxes because they are very high quality, and most include a ground buss. (By junction box, I assume you mean fuse box?)
You will also want to fuse any new power lead at or near the battery. I've used both MRBFs and ANL fuses for this. So a typical set up might be: Battery>80 amp fuse>8gauge leads>panel>panel circuits>loads.
The best tip I can give you is to always follow an ampacity chart, and size your fuses to the wire, not the load. So as an example, when wiring say a refrigerator from your panel which draws roughly 3 amps, you would likely run a 10 or 12 gauge wire to limit voltage drops and to protect that, you would use either a 30amp or 20amp fuse respectively.
The second best tip is to pretend your truck is a boat, and wire it like a boat. High quality wire, fully wired grounds, and water/vibration resistant connections. The wire terminals with the built in marine heat shrink seem expensive, but they are very long lasting, and the heat shrink provides very reliable strain relief.
The third best tip is that after you become comfortable wiring new circuits in your truck, get familiar with and use Anderson powerpoles for things like radio and fridge connections. Never, use cigarette type plugs if you don't have too. They are the invention of the devil and tend to fail when flying over the washboard. You don't discover that, until you realize your beer isn't very cold from your fridge.
