So my new shipment of little red boxes arrived a couple of days ago. I have had a slight miss around 1,700 to 1,900 rpm's for a month or so, nothing too bad to enough to get on my nerves. It would only happen on the interstate if I was going uphill and the rig was under a load. Anyway, I knew the previous owner had Autolite "professional" grade, wires, NGK plugs and a non OEM dist. cap. I also had a slight oil leak from the dist o-ring.
So I replaced plugs, wires, air filter, dist cap, rotor, PCV and o-ring. All of maybe 3 hours of work until the "professional' grade rubber came off the #6 cylinder plug while I was trying to remove it. Of course it had to be the worst one. I will save all the drama but it came out in pieces after a (6) hour struggle. Other than that it went like cake and was not difficult at all. Even got the timing right the first time around thanks to a great write here on MUD. Still need to do the fuel filter but after the struggle with the spark plug rubber, I was happy to have it overwith.
I would like the experts here to look at the plugs and let me know what you think. I know how to read 2-stroke plugs very well but not that much about car plugs. These look very, very lean to me.
My rig runs like a new one and the miss appears to be long gone. I actually enjoyed doing this work, I had a local shop quote me $700 to just install these parts, I about fell over. If not for the #6 plug issue, this was easily a 3-4 hour job. Here are the pictures, I look forward to any advice or comments....
Thanks in advance guys....
Curt
Curt
. I do enjoy learning though, it's all good!!
