- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,500
It is used as a Flyback diode. A voltage spike , after shutdown, can happen and cause issues. Never was a problem until more modern semiconductors were appearing. Not to be to long winded, review some info. Technology went so fast that those years merging old and new went away. That coil you have was an answer for that period.
I've never seen it, that's why I wondered why it was a diode vs noise suppressor vs capacitive discharge module vs secondary ballast resistor.
Maybe a Japanese fluent Mudder could tell what the box & label says?
The ballast resistor bypass wire (yellow in your diagram) does not need a diode because it is only hot during engine cranking. The purpose of this wire is to make cold weather starting more reliable (like -20C). I don’t know if you need this in Ecuador, but if you live up above the snow line it might come in handy.
I found this Instructions Sheet in one of the Boxes of the NipponDenso GT Hi DELUX Coil's
