"Ballasted ignition systems were designed to accommodate a wide range of operating conditions. A 3 ohm coil can only produce it's power when it is being supplied the necessary 12 volts. This means that in cold cranking situations when the batteries voltage dropped, the coil wasn't receiving enough power to create a spark.
On the flip side, there is the 1.5 ohm coil which is happy to operate in these lower voltage scenarios. Unfortuantely, they would burn out quickly if operated constantly at 12 volts. The solution to this problem was the ballast which reduces the voltage down to the 6-9 volts the 1.5 ohm coil prefers. It isn't, however, just that simple. In order to maximize the coil's output during starting, ballasted ignitions have a ballast bypass which sends 12 volts directly to the coil during startup. This doesn't create any issues for the ballast because the jump wire now creates 12 volts on both sides of the resistor. There is no longer a current flow, so the resistor doesn't do anything."
