Question-
I've been shifting into neutral before coming to a stop at a red light. What I mean is the light is green 100 yards out and turns yellow then... So I'm traveling at a pretty good clip and need to stop at the light.
Seems as though the vehicle stops a little "better" when I take it out of gear.
Cause your not trying to slow the engine and vehicle at the same time.
Good or bad habit?
If I understand the situation correctly, you are driving along and see a stop light in the distance. You remove your foot from the throttle and put the transmission into neutral (from drive). You then proceed to apply the brakes.
My first thought is that you are putting less stress on the drivetrain and more stress on the brakes. I figure this because the engine is no longer turning the drive shafts and, thus, is not actively turning the rotors. The wheels (and the rotors and the drive shafts) are rotating purely due to the forward momentum of the vehicle. The engine output is completely independent of the rotors at this point and is therefore not being resisted by the action of the brake pads on the rotors.
To put it simply, I believe that this separation would keep the force of the brakes from resisting the engine's output. Perhaps I am incorrect, but it would seem that the opposing forces (the brakes wanting to stop the car and the engine wanting to propel the car) would put stress somewhere in between the engine output and the brakes, possibly on the transmission.
The reason it feels like your car is stopping better is because the engine is not propelling the car as you try to brake. One-hundred percent of the braking force is going to stopping the car, whereas if you hadn't shifted into neutral, some of the braking power would be put to counteracting the force delivered by the engine.
When I approach a distant stoplight or stop sign, I shift into neutral and do not brake. I let the natural friction of the drive train and the force of gravity slow it down. I know that the friction offered during coasting is not great, but it does exist. As I get closer to the stop, I will apply the brakes, but I have already slowed down a bit, so the force needed by the brakes is not as high.
I hope I didn't just make a fool of myself!
