What about a REgear?
I dont speak metric so your size is pointless to explain to me without converting it to std,
If you've gone up considerably your subconsciously lugging the engine as it will be out of its torque curve and all the advertised "power" is misleading you...
just a thought
just a thought
Even with all the tips that you are getting here and good ones they are, 10mpg is wrong in every way. Maybe if you were running 315's with a 6 inch lift I could see you drop that low. I'd ask the dealer for a check and see what they find. My FJ40 gets a whopping 14 MPG at 70 and I thought that was bad! I own a 07 Tacoma double cab 4x4 with 265's and it will get 330 miles a tank ( around 18 gallons) when I stick strictly around the city. In the highway, I have a heavy foot and can get 350 miles on the same 18 flirting with 80 mph. The motor and weight shouldn't be much different I'm guessing but I did notice one factor. The Tacoma doesn't require 91 octane but the couple of times that I did use it, my mileage dropped considerably ! I didn't even hit the 300 mile mark before the gas light went on. So in essence I lost 30 miles on a single tank driving in the city. I believe the FJC is required to run on minimum 91 but just for curiosity, try running 87 for one tank and see if anything changes.
