Could there be another sensor that can be causing this?
Any suggetions?
About a year ago I was trying to fix the same CEL code on mine. I systematicly replaced all the EGR components. Nothing worked. Finally I tore off the top half of the intake to clean out the EGR tube through the plenium. Its a couple hr job and I wasnt sure I could do it. Well, the EGR path/tube was completely blocked solid with guk. It took quite a while to clean it as nothing disoves that stuff well. In the end the thing that worked best was boiling water poured in/through there repeatedly(it is off the engine at that point). That finally cleared my code and it hasn't come back since. Before replacing anything I would tear it down enough to see if this passage is blocked/constricted. Live and learn.
There is probably more information on the P0401 code than any other topic except maybe "Which is the best tyre?".
There are 4 components to the EGR system plus the interconecting hoses and tubes. In decreasing probability of being the defective part:
* Interconnecting hoses and tube through the intake
* VSV for EGR
* EGR Modulator
* EGR Valve
* EGR temp sensor
* Wiring to the EGR temp sensor or the ECM (never seen this)
Failures of the EGR valve and the EGR temp sensor are rare but a few have reported that replacing these fixed the problem. Some guys have just replaced all of the above in one service so they have no idea what component failed.
-B-
The way to tell if your passage is blocked is fairly simple. If you have a vacuum pump, hook it to the EGR valve with the engine idling. As you apply vacuum, the engine should start to run rough and, if everything is clear, the engine should stall/die. The optional methods are to use an engine vacuum source instead of the vacuum pump, or to reach through the bottom of the valve with a BLUNT instrument and lift the valve manually.
Very good advice! IMO you can spend more $$ replacing parts, than letting a professional diagnose the problem.![]()
