Backwards trunnion race
TN
I’m reassembling the front axle and got excited so I installed the trunnion races backwards. There isn’t much lip to hammer them out. Can someone offer some advice to remove them?
Backwards as in upside down? The cone opens into the nuckle rather than the out? If there’s no lip to pound against, I’m not sure how you can hammer it out without damaging/destroying it.
One option might be a can of compressed air, such that you get at an office supply store to clean your keyboard. Shake the can, hold it upside down and spray the whole can into the race. This will supercool the race and potentially shrink it by a tiny fraction. Enough to unseat it. Just be aware that if you hit it with any force when it’s cold, you run a high probability of shattering it. I’d try freezing it and lifting it out with pliers. DO NOT TOUCH it when it’s frosted over!
I’d try freezing them with propellant. They may lift out. Especially given the cold will have most impact where the race has the least material volume - which is what it’s pressed into the knuckle. Just keep the stream focused on the race and not the knuckle. You want the knuckle to remain near ambient.
Did the same thing years ago.
Got out the dremel and cut a slot on 2 sides. Enough to stick a screwdriver into and get a good bite. Was able to hammer them out but i did need to buy 1 new bearing and race.
freezing it is your best bet, dry ice works great if you can get your hands on some
They are hard, so, cutting, grinding them sucks. The easiest way is to weld on a piece of scrap and knock it out.
I did that once to the top passenger side trunnion race. Of course you don't realize it until the s.o.b. is fully seated. I was able to get it back out without damaging it or the knuckle, but it took time and patience. I used a tapered mild steel punch that was softer than the race, a large brass punch and a 20 oz ballpeen hammer. It took about 90 mins to remove, but it was 100% fine and I was able to install it the correct way without issue. It's been in there for the last 30k miles without issue. Don't give up yet. Just be patient and don't be too afraid of messing it up. Worst case is you buy another bearing.
I was able to pound them out this morning in about 10minutes using harbor freight chisels and creative angles. The harbor freight steel chisels might as well be made of brass they’re so soft. They’re all rounded and flattened but the races seem to be undamaged. I’ll clean them up and take a closer look.
Thank you everyone for the help and ideas!!!!
I did that once to the top passenger side trunnion race. Of course you don't realize it until the s.o.b. is fully seated. I was able to get it back out without damaging it, the knuckle, or the race, but it took time and patience. I used a tapered mild steel punch that was softer than the race, a large brass punch and a 20 oz ballpeen hammer. It took about 90 mins to remove, but it was 100% fine and I was able to install it the correct way without issue. It's been in there for the last 30k miles without issue. Don't give up yet. Just be patient and don't be too afraid of messing it up. Worst case is you buy another bearing.
