backwards jumper cables
Missoula
While I was out of town working, my wife put the jumper cables on my 96 LC backwards. When I got home, I found 5 blown fuses (dome, cigar, ecu, efi, and wiper) and the fusible link burned. Temporarily repaired the fusible link (butt connector), and replaced all fuses. Wiper fuse continued to blow until I removed the rear wiper relay, which had obviously released the smoke from a couple components (stunk, cooked diodes or resistors).
Vehicle cranks well. No spark, no movement at tachometer while cranking. Replaced ignitor. CEL comes on and stays on while cranking. Opened ECM and found no visible component damage, nor any smell of burned electronics.
Have power at all fuses (tested with test light), and coil plug. Planning on buying a multimeter today, and picking up my scan tool to see what the CEL is.
Anyone had this happen to them? What did you replace to solve the no spark condition? ECM? Distributor?
Thanks,
Eric aka Gumbydood
Thanks,
Eric aka Gumbydood
Start with getting rid of wife, and then go fusable link and look at both fuse boxes, the one at you knee bolster and under the hood, the fusable link can look ok and still be bad
Fusible links don't do well with butt connector repairs. Replace them. Buy two or three sets, install one and hopefully it won't blow right away.
Is the CEL on with engine off, NOT cranking, key in RUN position?
Fuses are all good, verified with test light. Repaired damaged fusible link with butt connector (temporary for diagnostics only). Scan tool shows rpm when cranking, but no tachometer response, and code P1300, which google shows to be an igniter circuit malfunction, or no IGF signal to PCM. Bought and installed a new (used) igniter. Best guess is ECM. thoughts?
CEL light ON, both when key in run position and key in start position with engine cranking. I doubt the butt connector is the problem, but I will install a new fusible link.
There was another recent thread on this exact subject. Do a search to find their solution.
personally I have never seen a computer go bad due to being jumped backwards, our sales idiots do that more often than they care to admit to. you probably just missed a fuse or have other wiring damage although the wiring damage is unlikely.
heres your power flow chart to help track potentially overlooked fuses
View attachment 2089125View attachment 2089128
I just verified all fuses in both engine compartment and under the dash with a multi-meter reading full continuity on ohms (0.00). Installed a piece of fusible link and verified connection between battery terminal and junction block/connectors through all fusible links.
I found he other thread and his "fixed itself".......
One of the last things brought up was the alarm.
Do you have a factory alarm (RS3000)? If so, it could be bypassing it, thinking it could have fried something in it or the logic in it is disabling due to the burnout and disconnect.
If so, bypass (remove) the alarm system and try again.
Otherwise, go back to the basics and check for spark, fuel, air. There is a emergency troubleshooting chart for these posted in the FAQ's.
No factory alarm that I know of. Have fuel. Not a compression problem based on level of work starter is doing to crank engine. No spark, no tach, but scan tool shows rpm when cranking. I Clear the code and get the P1300 immediately upon cranking. Guessing the ECM input/output from the ignitor failed, as it's unlikely the new (used) igniter was bad. Gonna order a used ECM from the place I got the igniter and hope for the best. I have to leave for work again tomorrow evening, so I won't be able to install the new ECM until I get back in early October.
Thanks for the help
Thanks,
Eric aka Gumbydood
Install inline fuse in next jumper cable set. I did something once, dunno what but I watched the thick plastic coating on the cables boil off. This when I was a kid. Car ran fine after, go figure.
